Can I pull it??
Wes
05-17-2004 11:36:58
I just bought a JD 10 ft tandem disk. Will my 47 A pull it? I plow with a Massey Harris 3-16 plow and I don't think the disk will be much more of a load.
MIKE HANLEY
05-17-2004 15:31:25
 Re: Can I pull it?? in reply to Wes, 05-17-2004 11:36:58
Unless you are farming full time and are just using 1950's equipment on a couple of acres,,,, if you have the time why not go back and do it the way it was done in those days. That is in the 50's there were no such thing as weed killer spray. weed control was done with rotation and tillage equipment. We nhever went out and dropped a plow into a old sod field. In the fall of the year, we ran a quake digger over sod twice over about a week apart. Now the roots of the sod are pulled apart and it's much so much easer plowing. Plus with the ground part worked by the digger when the plow goes over the groung the ground is broken apart and will disc so much easer. Try that and then try plowing sod and haveing those PRETTY ribbons of plowed sod,,,,and then JUST trying to staring in the seat the first time though with the disc. Well try it both ways and see which way IS SO MUCH better.
Same way with corn stalks. Plows of the 1950's had no where the clearance the plows of today have. and when the yields went from 50 bu per acre to 80 plus bus per acre,,,it was hard to plow without plugging with cornstalks. The answer was to disc the cronstalks down with your disc FIRST. Do it twice, on bigger fields, first time over with the disc WITH the rows and second time over CROSSWAYS of the rows. Then Plow WITHOUT PLUGGING. Then Discing will be a piece of cake. The extra trips with tillage was just as much for weed control as it was for EASER tillage. And was just as imporant as rotation of crops. The fence row to fence row corn on the whole farm and the heck with livestock didn't come in to beening till the 1960's and didn't realy take off till into the 1970's. So if you out with 1950's equipment,,,why not run the stuff the way it was run in the 1950's.
MIKE HANLEY
05-17-2004 15:45:42
 Re: Re: Can I pull it?? in reply to MIKE HANLEY, 05-17-2004 15:31:25
If it is a 3PT disc or a disc with lift wheels you can control the depth of the blades. If you look back and the dirt is at or above the shaft,,,,,you are two deep, which easy to do in light soil that has been worked prior to plowing with a disc or digger.. If the dirt is over the shaft, what you are doing is GRADING with the shaft not discing.
PS. This kind of tillage will seprate the guys that say a 730 can;t pull over 3 bottoms and the guys that CAN go out and plow with 5 bottoms behind a 730. Amazeing how we forget the past and think the way we do it today was the way it was always done. How wrong that statement is.
Robert
05-17-2004 12:13:51
I'm pulling an 8' tandem in sugar sand with my '45 "A", and I can tell you it's all the tractor wants. It does pull the load, but I can tell the old girl is really working. Good Luck!
John T
05-17-2004 11:58:58
Wes, if its the first time ever on fresh deep plowed ground,,,,, ,and its a heavy wheel disc with good big blades that dig in and cut deep,,,,, its gonna be a *&^% of a load first time over with an A thats not in tip top shape (Traction could be a problem, got any duals???). However, if the grounds not rough,,,,, and it dont have real big blades or is not too heavy such that it dont cut real real hard n deep, sure it will handle it.
I got along much better with a good heavy big bladed 10 or 12 ft disk with my 720 or 730's than any A's I ever owned. I owned n used 8 or 10 ft discs with them (A's), but first time over fresh plowed ground with a 10 ft and an A wasnt settign any speed records in the heavy clay I farmed. Im NOT sayign an A wont handle it, Im sayign it depends on the ground, condition, weight, and blades on the disc.
Only way to tell with that particular disc and that particular A is to have at it, cuz a 10 ft on an A is within its theoretical limits at least, its NOT like you were gonna try it on a heavy 12 or 14 footer.
Let us know, Good Luck n God Bless
John T
