GENERALLY, Deere casting numbers are in pretty big raised letters, usually on the starter side of the block, maybe even behind the starter. If you still can't find it, clean both sides of the block, and it should be in plain sight somewhere. There are many places, including this site, to get kits, and I doubt if any are going to be "low priced"! Removing the sleeves will be tough without a good puller. It is very important to thoroughly clean the "O" ring grooves in the block where the bottom of the sleeves are sealed, and also the ledge in the top of the block, where the sleeves are pressed against by the head. Check sleeve "standout" to be sure the sleeves protrude the specified amount above the block deck for proper gasket sealing. Assuming the crank is fit for re-use without regrinding, be sure to get the correct bearing inserts (has someone ground it undersize before), and verify the clearances of the new bearings with PlastiGage. Use new connecting rod bolts. Check the valve lifters and cam lobes for wear, being sure to put the lifters back in the original holes, if reusing the cam and lifters. Check, also, the camshaft oil pump gear and the gear on the oil pump for excessive wear. Problems here are not as likely as with some of the newer tractors, but still possible. Have a machine shop check the depth of the valves from the head surface. Valve and seat wear cause valve recession, and hard starting. I'm sure others will respond with a lot of things I've forgotten to mention!
