720 Propane- 6 volt?
cdm
05-16-2004 13:26:33
I just took delivery of a 720 propane. Iam waiting on JD manuals. It has a 6 volt battery in it (positive ground). It barely turns the engine over. Is this the correct set up. My 730 and 720 gas are 12 volt.
Thanks in advance. CDM
Clooney
05-17-2004 03:06:47
 Re: 720 Propane- 6 volt? in reply to cdm, 05-16-2004 13:26:33
CDM, your 720 Propane originally came from the factory with 2-6 volt batteries in series giving it 12 volts [positive ground] for starting & running.. A lot of people now just use a single big 12 volt battery in place of the two 6's..
~I doubt that a single 6 volt battery will be enough to crank it over let alone also supply the ignition & fuel valves with enough power to operate.
~You want to be careful if you operate it on that single 6 volt battery [even for a short time] as the charging system still puts out over 13.7 volts & that means that 6 volt battery is getting severely overcharged [remember you are sitting on that battery]....
[email protected]
John T
05-16-2004 14:07:11
CDM, my thinking would be it had two 6 volt batteries in series (my diagrams show two 6 volt batteries in series) but one went bad and was removed and never got replaced. (Isnt your battery box big enough for two 6 volt batteries???) If a person were to use two 6 volters in series, its better if they are well matched in size, rating and age. If you go with a new single 12 volt, I would use a good heavy duty high amp/hr or CCA rated (maybe 900 to 1050 CCA). A good heavy duty 12 volt of today may well store and deliver more energy than two 6 volters in series used years ago.
Looks like youre gonna need a new 12 volter or a 6 to match the one you already have.
Good Luck n God Bless
John T
