Randy, cold weather can sure affect charging systems, the battery is less efficient plus engines are harder to crank, making for more demands on the charging system in general. Moisture and corrosion can have an affect on simple things like the generators brush hold down spring assmeblys also. In addition, the brushes may be getting worn down causing marginal or intermittent performance. The light coming on brief periods may not mean too serious of a problem just yet (maybe brushes getting worn short or belts bad or loose), but here are a few thigns I would do for a winter tune up. 1) Make sure the belt is tight and not worn or glazed. 2) I would clean and light lube the brush hold down spring assemblys. Make sure they raise and snap down tightly to push the brushes tight down against the commutator. If they are worn too low, peformance can weaken or even stop. Where possible, I clean/polish the commutator to remove grease and/or oxidation. (These are a lot of things that can be done just by removing the band over the brushes if your generator is so equipped) 3) You might want to remove, clean and wire brush, and re attach and tighten wire terminals and battery connections if any appear suspect. 4) Inspect the battery to make sure the electrolyte level is above the plates in all the cells. If any appear gray or milky, a cell may be going bad. If the brushes arent worn too low and the hold down springs tight and the commutator is clean and belt tight, if the light still comes on and you have a good battery, post back and I will guide you through troubleshootuing to see if its generator versus a voltage regulator problem. If the light comes on and stays on you might ground the Field post (smaller of the 2) on the Generator and see if she charges then, if so, the Regulators Field control relay or points may be going bad. Similar, if theres no charge running but if you jump the VR's BAT and ARM (or GEN) terminals together she charges then, the Regulators Cut out relay may be bad. Check the belt first and battery level, make sure the brush hold downs are free and push the brushes down tight and post back or e mail [email protected] any questions. Good Luck n God Bless ya Randy John T
