Block for M, 40
Bus Driver
05-16-2004 08:32:35
I have an engine for a 40 (M64T block) that was (supposedly) rebuilt. Bought the tractor for parts. My confidence in the quality of the work is not high. When reassembling the tractor, the lower right bolt boss was broken from the rear flange of the engine. My guess is that the transmission shaft/clutch splines were not aligned and an attempt was made to pull the tractor together with a bolt through this boss. The lower bosses would be the greatest tension point on a standard tractor, so I hesitate to use the engine as is. In looking at the M/40 crawlers, it appears that the engine is cantilevered from the clutch housing flange so that the tension there would be on the upper bolts and the bottom would be in compression. If that is true, the block I have would be well suited for a crawler. Have I correctly thought this through?
Mike M
05-17-2004 12:47:26
 Re: Block for M, 40 in reply to Bus Driver, 05-16-2004 08:32:35
I have seen more than a few of those that were broken and welded and still holding together. It is not a pretty sight but for just a work tractor you could just weld it back up.
