37B long frame
Hoover_brett
05-15-2004 23:21:33
Anyone have a gas tank or know where I can get one for a long frame 37B. A very kind mouse built a nest in mine and put a nice big hole in it.
Bus Driver
05-16-2004 08:44:32
 Re: 37B long frame in reply to Hoover_brett, 05-15-2004 23:21:33
I have repaired 3 gas tanks quite successfully and no one believes that my repair will work. In the early days of epoxy, in some applications, multiple layers of brown kraft paper was used as the reinforcing material instead of fiberglass. I hand sand (hand sanding makes no sparks) the edges of the hole to clean metal, at least 2" past the edge of the hole, clean with lacquer thinner. Use the slowest setting non-filled (JB Weld has fillers) epoxy resin available. Coat the edges of the hole with the mixed epoxy, place paper (grocery bag) on the epoxy, saturate the remainder of the paper and add another layer of paper, saturate it and work out air bubbles between the layers. 4 layers is plenty, I use only 2 for holes not over 1" diameter. Let cure for 48 hours. Probably good to then use sealer in the tank per manufacturers instructions.
