1943 john deere b
steve
05-15-2004 18:45:55
Clutch works fine but makes grinding noise when engaged and disengaged. Wondering if someone can email a diagram of the clutch assembly (better than I & T shop manual), or tell me where I can get a diagram or what the problem might be.
F-I-T
05-15-2004 20:57:25
 Re: 1943 john deere b in reply to steve, 05-15-2004 18:45:55
third party image
Steve:
Not sure if this is the correct one for your serial number, but it ought to be bigger than the I&T illustration. On the grinding, there is a bearing in the pulley, but it only tunrs when the clutch is disengaged. There is also a bushing farther back. Maybe wear in the bushing is allowing it to rub on the dust cover or first reduction cover? Not sure I'm any help there.
Frank
steve
05-19-2004 18:23:02
 Re: Re: 1943 john deere b in reply to F-I-T, 05-15-2004 20:57:25
Thanks for your help. The diagram was the right one, and very much appreciated. Helped a lot when tearing apart and reassembling. Thanks again.
B JDfarmer
05-15-2004 21:48:24
We had a B that did the same thing. I would put new springs in it and that should solve the problem. It did for me.
steve
05-19-2004 18:18:12
 Re: Re: Re: 1943 john deere b in reply to B JDfarmer, 05-15-2004 21:48:24
Thanks for your help. We tore it apart and one of the springs was bad. Fixed that and clutch works fine. Thanks again.
