430 Throttle and Gov linkage
Dave - Ia
05-15-2004 17:14:37
What is the procedure for adjusting the throttle and gov. linkage on a 430. All my manual says is one rod is to be 2 turns long and the other 2 turns short. The full procedure is in the book for a 40 which I dont have. Any information would be appreciated.
Clooney
05-15-2004 17:46:19
 Re: 430 Throttle and Gov linkage in reply to Dave - Ia, 05-15-2004 17:14:37
Dave, this won't be easy to write...
**Governor rod adjust**
Start by moving the hand throttle lever to slow idle,, then place one flat washer over the end of the control rod [runs from the hand lever],, then install the vertical connecting rod on the control rod,, then push the governor lever down as far as you can,, then adjust the yoke on the vertical rod so it's hole lines up with the governor arm hole,, then unscrew the yoke 2 more complete turns,, then install the yoke pin through both the vertical rod & governor lever,, then tighten the lock nut at the yoke,, then move the hand throttle to wide open,, then install the second washer & spring on the control rod..
**Governor to Carb rod adjust**
Install the carb to governor link ball joint on the outside of the small vertical governor arm [the one with the stop pin in it],, then move the hand throttle lever to wide open,, then roll the carb throttle shaft lever all the way to the front, then adjust the carb to governor rod so the rod just goes into the carb lever hole,, then screw the carb to governor rod into the ball joint 2 full turns,, then tighten the lock nut..
Any questions just post back or E-Mail..
[email protected]
Dave - Ia
05-16-2004 10:22:58
 Re: Re: 430 Throttle and Gov linkage in reply to Clooney , 05-15-2004 17:46:19
Clooney, thank you very much. I was mowing yesterday afternoon, and the rod from the hand throttle to the gov. came out of the yoke. It was only in a couple of turns. I tried adjusting the rod from gov. to carb. thinking I could get the other rod into the yoke further but did not have any luck, but I had the throttle lever in idle position. I will try again this afternoon and see what happens. Thanks again.
