JD 50 PTO Leak
Larry B
05-14-2004 19:37:02
My JD 50 has independent PTO which leaks the 30wt oil used to lubricate the PTO clutches into the trans case. I suspect the problem in in the PTO pump seal area which requires disassembly of the whole back of the tractor to service. It seems to pump about one quart per hour into the trans sump. I have adjusted up the clutches fairly tight and left them engaged. I use the short pto engagement lever next to the trans shifter to engage and disengage the pto now. The problem is that I have to keep draining off one quart of trans oil every hour and now I am adding it back into the pto housing to keep it full. What if I connected the two sumps (trans and pto) through there respective drain ports with some tubing? The pto would stay full, level with the trans sump, the pto pump would continue to pump, and if the clutches remain engaged they should not suffer any harm running in 90wt instead of 30wt. I just don't have the time to fix it now but don't want to do something stupid. What am I not thinking of?
John Van Valkenburgh
05-17-2004 21:53:27
 Re: JD 50 PTO Leak in reply to Larry B, 05-14-2004 19:37:02
Larry,
I don't think it's a good idea to run gear oil in the PTO. I seem to recall that the Gear oil will damage the PTO clutch parts. My 50 has a similar problem. I think the only solution is to pull the rockshaft/rear housing off and replace all the seals. That rear housing is especially heavy so be careful.
I've got all new gaskets and seals on order. I'll probably have my 50 apart this comming weekend. Not really looking forward to it.
Best of luck,
John
