FUEL STARVATION?
JWS
05-14-2004 19:17:02
I'VE BEEN WORKING ON JD M TO GET STARTED, REPLACED MOST IGNITION COMPONENTS AND HAVE EXCELLENT SPARK. COULD NOT GET FUEL TO ENGINE. REMOVED, DISMANTLED AND CLEANED CARB. WILL START BUT NOT RUN UNLESS FUEL SPRAYED THRU AIR INTAKE. HAVE REMOVED CARB. AGAIN. ANY SUGGESTIONS? THANKS IN ADVANCE!
Loren NC
05-16-2004 03:10:23
 Re: FUEL STARVATION? in reply to JWS, 05-14-2004 19:17:02
I read Clooney's reply and your second post about what you found. What I didn't see was any mention that you pulled the screen in the back of the carb. That is a MUST DO. Look at where the fuel line attaches to the carb. Unscrew the fitting that the line goes into and pull it out. I had the same problem you are having and my carb screen was plugged with fuzz of some sort. Get it out, get the screen clean and I'll bet you have gas flow.
Clooney
05-15-2004 09:07:32
JWS, those "M" TSX carbs have a fine screen strainer right in the back of the carb fitting that the fuel line attaches to.. Pull that inlet fitting out & check that screen [those are commonly found plugged on the TSX carb]..
~You MUST have fuel flowing out of the carb's bottom drain cock when you open that.. If no fuel flow out the bottom of the carb but you have a good fuel flow at the line going to the carb then suspect that inlet screen or the float or needle & seat are stuck [or stuck shut]..
~If that carb was assembled at one time without the little needle clip installed between the needle top & float tang the float could raise but the needle could remain stuck closed & not allow fuel flow..
Any questions on the above just post back or E-Mail...
[email protected]
John T
05-14-2004 20:42:37
If the carbs good??? Hows the fuel flow out the tank to the carb inlet???? Ive seen clogs in the tank outlets,,,,, ,,,or in the screen mesh up inside the tank if the sediment bowl has one,,,,, ,,,,or the sediment bowl inlet pipe,,,,, ,,,, or the lil side hole outlets at the top (where gas enters to fill the bowl) if it has one and its that style. If the carbs float, needle n seat assembly are restricting flow (maybe dirt in the seat or something is restricting the needle), it could possibly start n run decent until the bowl level drops and then she would starve out, but you say you cleaned it?
If the carb has no fuel restrictions and is set????? Check the flow FROM TANK TO THE CARB INLET,,,,, ,,,, See if when you remove the gas cap fuel flows to the carb better (air lock).
Look inside the tank best you can to try n see any restrictions??? You have an in line filters or shut offs or other jury rigged fuel line apparatus which could hamper fuel flow??? Good clean fresh water free gas is also something to consider. If theres insufficient flow TO THE CARB,,,,, , or if the proper float level isnt maintained,,,,, ,,,or theres a needle n seat restriction,,,,, ,,, shes gonna starve for fuel even if the rest of the carb is good and adjusted proper.
Good Luck, God Bless, Let us know.
John T
JWS
05-15-2004 05:02:56
 Re: Re: FUEL STARVATION? in reply to John T, 05-14-2004 20:42:37
Thanks for reply. The gasket/diaphragm? inside the carb (TSX 245) is not in very good shape. I will replace if avail. Fuel is getting into carb. as float and needle seem to be functional and fuel is in bowl when I dismantled. I am not getting any fuel thru drain cock on bottom of carb. I have removed and cleaned but still no flow. Load adj. needle removed and cleaned also. What is setting for load adj. needle to start? Idle adj. has not been touched. Fuel flow from tank to carb seems very good. Replaced fuel filter complete recently, all lines removed and cleaned, checked. Thanks for your expertise!
John T
05-15-2004 06:45:22
 Re: Re: Re: FUEL STARVATION? in reply to JWS, 05-15-2004 05:02:56
JW, youre welcome to all I gotta offer, but I have no TSX expertise. HOWEVER If youre NOT getting flow out the drain cock, shes never gonna run. If the flow is slowwwww out the drain cock, she may not run until the bowl is filled (takes way too long to work) but then would only run a while until the level is depleted. The fact it had gas in it when you removed could be the flow is real slooooo ooowwww but eventually fills the bowl so that dont help you much really.
I still think flow in the line to carb is restricted (sediment bowl or tank outlet etc) orrrrr rrrrr rrrrr r theres a needle n seat restriction or a restriction at the carbs inlet or maybe the carbs not venting or the float or needle is restricted (gum n varnish) and not dropping down. I dont work on TSX carbs, but can you remove the bowl and turn the gas on and when the float is down (insure BOTH it and the needle are dropping down) GAS OUGHTA RUN OUT PAST THE NEEDLE at least the size of a lead pencil lead or so. IF NOT, (and float n needle drop down) theres a restriction in the needle n seat or at the the carbs inlet or from the tank to the carb.
With the line removed to the carb, it ought to run free n strong the size of the lines ID. If NOT, the tank outlet or the sediment bowls inlet pipe or screen or the sediment bowl assembly is clogged or the tanks not getting air (check with cap removed).
If she runs out the needle good with the bowl off but theres no flow out the drain cock with the bowl replaced, perhaps there a clogged carb vent and she air locking.
Sorry Im not a TSX man but the above still holds true of about any carbs. You gotta get good flow out the drain cock for her to run and if its not, its either a restricted flow to the carb,,,,, ,,,or a partly clogged needle n seat,,,,, ,,,,, , or the float and needle arent dropping down (gum or varnish),,,,, ,,,,, , or a clogged carb inlet,,,,, ,,,,,or the carbs not venting (air has to eacape for gas to fill the bowl).
Let us know, good luck n God Bless. Maybe a good TSX man can help us all learn something but theres gotta be a flow to carb restriction or carb inlet or neelde n seat resitriction it looks like to me if the carb and tank are venting and the float is dropping down lowering the needle. Are you sure the drain cock is free and would allow gas out???
John T
