720d noise update
Hilltopper
05-14-2004 06:34:57
I have discovered that this noise is not heard under decompression. It shows up very loudly cranking under compression with the fuel off. It is a much sharper noise than a loose flywheel. I can not hear it at the crankshaft with a stephscope. It shows up at rocker arm cover and the transmision imput shaft area. I am thinking it must be internal in the pistons as it has high oil pressure. It always runs pegged on oil pressure with the adjusting screw backed out. I have checked it at 40# on a gauge. This is not a worn out engine. It burns little oil. Engaging the clutch cuts the noise in half. Any ideas? thanks
Clooney
05-14-2004 09:23:41
 Re: 720d noise update in reply to Hilltopper, 05-14-2004 06:34:57
Hilltopper, you say...
Quote: "It shows up very loudly cranking under compression with the fuel off">>>
_That says it needs the compression forces to cause the noise to appear.. Loose pistons, loose wrist pins, loose counter weight, loose center main bearing, loose end main bearings, etc.. It probably also tells you the problem isn't the fuel system or injector related..
Quote: " Engaging the clutch cuts the noise in half. Any ideas?">>>
_That would be normal for a lot of noises as it adds rotational mass to crankshaft & that lowers the spike firing impulses [or compression impulses]..
Quote: "I am thinking it must be internal in the pistons as it has high oil pressure. It always runs pegged on oil pressure with the adjusting screw backed out">>>
_Well the good oil pressure is a good sign but a single bad bearing usually won't lower the oil pressure very much.. Wear on all the bearings will.. Run that tractor under a plowing load for a few hours & I'll bet the oil pressure will come down..
Quote: "It is a much sharper noise than a loose flywheel">>>
_I have had gas 70's sound similar with both a loose counter weight & loose cam gear.. Have you tried running it with the 1st reduction cover filled partially up with 140 weight gear oil.. That little lower idler oilier gear [in the lower rear corner of the 1st reduction cover] can make a real sharp rap if it is missing a tooth or isn't getting lubricated [worth a quick try anyhow]..
~You might want to try the cranking test again first with one intake [or exhaust valve held] open then with the other held open.. Maybe that will tell you what side & if the lack of compression is effecting the noise or it�s something else..
~What I usually do in case like yours is to write everything down as I run the tests then after a while you can compile a data sheet & maybe see a pattern on what does & doesn�t change the noise.. That might help isolate the problem by adding or eliminating certain mechanical areas.. If after running a few tests all the data show all the roads lead to Rome then the problem must be in Rome..
~Keep us updated on your progress & check back here once in a while.. Maybe we�ll think of something new to look at & add it here..
*** I just thought of one more.... I had a gasser with an internal noise a few years ago & was having a hard time cranking it to check for the noise & running it was too hard to work with so I belted it up to my quietest tractor [an old worn out B].. That allowed my to try different things while it quietly spun away knocking all the while.. I even pulled spark plugs with it spinning.. That was the one I found the loose cam gear on� Just be careful you don�t get caught up in the belt or there will be a new noise coming from that tractor..
****One more--- Try taking the end off the stethoscope & listening to area noises instead of component noises maybe that will help isolate the area.. You can slide that open end into oil fillers, trans filler, vents, through filler holes, etc..
[email protected]
Hilltopper
05-14-2004 15:18:32
 Re: Re: 720d noise update in reply to Clooney, 05-14-2004 09:23:41
Clooney, i went down your list and tried one more thing. I pulled the timing cover, put a pipe wrench on the crank and as I turned it I heard a familar noise. I reached up and found the double idler gears were moving in and out and flopping some. It would have stabilized some with the clutch engaged. This would have caused the knocking sound. After I finally got it off the stub shaft. I removed the bearing which sure enough was moving back and forward due to wear in the snap rings. There is also a slight grinding in the balls of the bearing. This does not seem like much, but as the sound is magnified it became much. This is a later tractor and uses a wide bearing. Ser#167xx I have ordered a bearing from Bumper to Bumper, but I will need to order the snap rings from Deere to get a good job. I hope this will solve the problem. I am not putting the pony back until I have run it and seen if this is the answer. Thanks to all.
Clooney
05-14-2004 17:38:43
 Re: Re: Re: 720d noise update in reply to Hilltopper, 05-14-2004 15:18:32
Hilltopper, that cam idler gear is a common problem on the 70D & 720D.. That later 730D's aren't too bad as they had the later gear, bearing, & stub shaft set-up that used a bolt.. A lot of 720D's were updated to the 730D gear & bearing at overhaul time..
~A loose idler gear usually doesn't make quite that pronounced knock as you explained but they can knock if that gear moves in far enough & contacts the case or twists enough to contact the cam gear... Look for witness marks on the case, gear, & cam gear [or just push on the gear & see if you can make it contact something]..
~I think you will find that even with a new bearing & snap rings that the bearing will still have some end play in it's bore or on the stub shaft.. I usually have to machine up a thin shim to help with the clearance.. I also use Loc-Tite 680 to hold that bearing tight in the gear bore.. For the outer smaller snap ring I usually need a very thin shim behind the bearing & use 2 thinner snap rings with the openings opposite each other in the outer groove instead of the thick original one.. If you have to do any shimming try to shim it away from the block if it was real close or rubbing there.. I have even machined up a spacer to go outside of the outer snap ring & hold the ring in tight, that machined ring is just thick enough to contact the timing cover.. I then Lock-Tite that ring on.. With all the above I can usually get all the side clearance out of the early gear & bearing.. But really the best thing to do is install the later 730D bearing & gear [in fact Deere offered a retro fit kit at one time]...
~If you do find that your gear is still slightly loose let me know & will send you a picture of that ring I make up installed on the stub shaft..
~When you get it back together & running be sure to re-check your injector timing as that could change once that idler gear play is removed..
~Let us know how it turns out?
[email protected]
F-I-T
05-14-2004 08:36:34
HT:
The timing gears were know to go bad, but this was more typical of the 70/early 720 D's. Could it be that the noise is telegraphing across the cam shaft to the right side? Since it comes up after you go to compression, the only thing that you are adding to the mix is allowing the exhaust valves to ride the cam.
On the oil pressure, it's not uncommon for the relief valve spting to stick fast or be partially clogged with debris, so that the oil pump is not dumping excess volume at pressure. I have cured those by backing screw out all the way so the oil can blow any trash out, then the screw will adjust the pressure to the desired level.
Frank
Mike M
05-14-2004 07:23:23
Oil pressure has very little connection to engine condition on an engine especially a 2 cyl. These have very high volume gear pumps. It does seem strange that you can get that much pressure with the adjustment backed out it should change alot. Given the nature of 2 cyl. diesels to run with more problems then any other engine made and the abillity to lug themselves to selfdestruction I'd go in take a look before more stuff breaks.
