47B GOVERNOR END CAP REPLACEMENT
CHUCK IN MICHIG
05-13-2004 22:21:40
CAN I REMOVE AND REPLACE THE GOVERNOR END CAP ON MY 47B WITH THE GOVERNOR STILL ON THE TRACTOR. THE ONE ON THE TRACTOR HAS BEEN CRACKED AND IS WELDED, AND LEAKING OIL. I ALREADY HAVE A REPLACEMENT FOR IT. IT IS ON THE LEFT SIDE OF THE TRACTOR ABOVE THE FLYWHEEL.
Mark
05-14-2004 09:16:13
 Re: 47B GOVERNOR END CAP REPLACEMENT in reply to CHUCK IN MICHIGAN, 05-13-2004 22:21:40
Yes you can replace it while on the tractor. But you need to remove the Mag or Dist. first. That gov. shaft is spring loaded, and will push the rotor or shaft out of the mag or dist. if not removed prior to replacing the end cap and bearing. You will have no idea if the shaft with the drive lugs and the driven lugs are still in line.
chuck
05-14-2004 18:05:54
 Re: Re: 47B GOVERNOR END CAP REPLACEMENT in reply to Mark, 05-14-2004 09:16:13
Thank you for the advise. I will remove the Mag before beginning.
