3010D shifting
Bob
01-27-2004 06:38:24
I have adjusted the free play in the clutch twice in the last year, 250 hours.
It doesnt shift as smoothly as it should..It kind of hangs up at times when going from park to a gear, requiring extra pressure to shift, doesn't grind or have gear pressure.
Is there any adjustment or is my clutch getting worn or other?
It is not a significant problem only a concern....
DON
01-27-2004 08:11:54
 Re: 3010D shifting in reply to Bob, 01-27-2004 06:38:24
WHEN COMING OUT OF PARK ,IF YOU ARE ON AN INCLINE IT WILL PULL HARD . SOMETIMES IF THE LOAD IS REALLY HEAVY ,LOADED WAGON PUSHING/PULLING ON THE TRACTOR YOU WILL HAVE TO FORCE THE LEVER TO THE FIRST STATION AND GO TO FORWARD OR REVERSE TO RELIEVE THE LOAD, IT WILL THEN SNAP OUT OF PARK. AS FAR AS THE CLUTCH ADJUSTMENT YOU CAN BURN THE CLUTCH OUT IN A COUPLE HOURS IF YOU ARE SLIPPING IT A LOT. ARE YOU GREASEING THE THROWOUT BEARING,IT COULD BE SEISEING AND BURNING THE CLUTCH FINGERS OFF. DONT THINK IT WOULD LAST 250 HOURS THOUGH. JUST A THOUGHT DON
