Fuel line kit part number
mikeprothro
05-13-2004 06:52:42
I keep seeing these fuel line kits to fit the letter series tractors showing up on e-Bay. I would like to get one for my 48 B, but it just goes against the grain for me to buy it over eBay when I know I can most likely get it from Deere or elsewhere cheaper. Every one has to make a living I guess. Anyway it has the correct nuts, and fittings but appears to have a copper line. You have to sweat one end on. My original was a steel tube, but not a big deal after you throw a little green paint on it. Anyone have a part number for this? I know Roberts sells the fittings only, the kit would be handy. Any help would be most appreciated. Got the old B out yesterday for some mowing before the rain hit. It was the first time I have worked it since I've owned it. I drug it out of a briar patch winter before last, it had a tree growing up through it. I had another identical tractor for parts. I went completly through it, rear end, trans, engine, new tires etc. Yet to paint it. To hear that old girl popping along cutting grass made it all worth it.
Thanks, Mike
Dave K
05-15-2004 08:58:00
 Re: Fuel line kit part number in reply to mikeprothro, 05-13-2004 06:52:42
If you take your old line to NAPA or any of those places they wil make one up for you.
Dave
mikeprothro
05-13-2004 18:42:57
Many thanks for the help guys. The one I see on eBay I'm thinking is from Deere. I have a home made line using steel tubing and brass fittings now as my original was rusted away. I want to go with the original fittings/ nuts etc. as I am preparing to paint. Thanks again,
Mike
DON
05-13-2004 18:22:59
LOOK IN AN UNSTYLED A OR B OR WHATEVER AND THE FUEL LINE FITTINGS AND NUTS ARE STILL AVAILABLE FROM DEERE. I USE STEEL BRAKE LINES FOR THE LINE AND BEND IT LIKE THE OLD ONE. I DONT HAVE A PART BOOK TO LOOK THEM UP BUT IF YOU CANT FIND THEM LOOK IN THE ARCHIVES AS I HAVE ANSWERED THIS QUESTION BEFORE OR LET ME KNOW. DON
Dan 41 B
05-13-2004 08:07:13
Mike I got a fuel line replacement for my 41 B from Deere and it is steel not copper part number ab2751r. It wasn't cheep as it was $25.00 I don't know what they are on e-bay but that is what mine cost for my 41B. Hope that helps.
Dan 41 B
Mike M
05-13-2004 07:14:43
Another chioce is to make them yourself I have used crankcase oil lines from salvage tractors sometimes they are close with a little bending other times I just use the ends and nuts from them. I cut them off flush where they go into the fitting then drill out the old line and solder in a new copper one.
