G-MAN : JD 4010 block weep holes
Kevin
05-13-2004 06:16:34
G-MAN
On a previuos posting you were talking about weep holes. Where are these weep holes located on the block. I have a 1961 4010D that has been painted several time with a brush and most likely these holes got plugged up. Looking at the block I do not see any holes. I'd like to make sure that I do not have a problem. Thanks!
Kevin
txblu
05-13-2004 09:37:11
 Re: G-MAN : JD 4010 block weep holes in reply to Kevin, 05-13-2004 06:16:34
I'm not G-MAN but since your post is unanswered I'll help
The sleeve is held in place by the main casting on the bottom and the top (and secured by the downward pressure from the head). The seals are in the lower part of the casting around the cylinder sleeve.
The bottom (mentioned)is at the top of the crankcase and is where the block starts rounding to allow for the crank to turn.
As I recall (brain dead) they are on the same side as the intake/exhaust manifolds. There is one per cylinder and are around .050 in dia. They are easily plugged, so your painter or previous owner may have plugged them for some reason.
A devious person would tend to plug them prior to a sale if they were leaking. Indicates major expense/effort to replace seals.
On my 4020 they were open and leaking (course I didn't know what that meant when I bought it..... do now). On the 4010, they were plugged but I know the engine has a fresh overhaul so I'm not too worried about it for now.
Kevin
05-13-2004 09:54:53
 Re: Re: G-MAN : JD 4010 block weep holes in reply to txblu, 05-13-2004 09:37:11
txblu,
Thanks for your info! I'm a little apprehensive about cleaning them out.
Kevin
txblu
05-13-2004 19:43:06
 Re: Re: Re: G-MAN : JD 4010 block weep holes in reply to Kevin, 05-13-2004 09:54:53
Here's a thought.
Watch your radiator for signs of oil. It floats and will be on top when you remove the cap and look down, if you check it before running the engine for the day. If you see oil, start sweating.
When you drain the engine oil, be very careful to catch the first "whatever that comes out". If it is green then you are close to thinking about when you are going to do that overhaul. If black, keep on grinnin. Heck with the holes.
Good luck.
txblu
RickB
05-13-2004 16:40:19
Go ahead and clean them. Better to know than to wonder.
txblu
05-13-2004 19:34:35
 Re: Re: Re: Re: G-MAN : JD 4010 block weep holes in reply to RickB, 05-13-2004 16:40:19
I'm not so sure I share your enthusiasm. Here's why. If they leak and cause me to do an overhaul, I would be doing an overhaul anyway (and worrying about cost and what else would be found and all) so where's the lift? Not any. This way I can be thin, dumb and happy. Well, sorta thin. Grin
txblu
