1240 planter pros cons
TB SCOTT
05-13-2004 06:14:00
Im looking at a late 1240 & was wonering good and bad points and what to look for for wear points.
Jason Karels
05-13-2004 13:00:08
 Re: 1240 planter pros cons in reply to TB SCOTT, 05-13-2004 06:14:00
At that age, pretty much everything. The areas I have worked with are the down pressure springs, and press wheels. Where ever there is a bushing, they could be wearing, also. If you are using the finger mechanisms, they will wear also. I used these models when I started farming ecuase they were cheap to get, but they are expensive to work on now. I decided to go to a 7000. More expensive up front, but parts are much more reasonably priced.
