630 Dead
Greg
01-27-2004 06:18:59
While plowing snow last night I was backing up (tractor running at high rpm) when suddenly the 630 quit running, there is no spark at the plugs or points, is it possible that the coil would fail that suddenly or do I have more serious problems.
John T (Troubleshooting)
01-27-2004 08:24:42
 Re: 630 Dead in reply to Greg, 01-27-2004 06:18:59
Morning Greg, To answer your question, yes its possible a coil could fail all that sudden, but theres also many other possibilities, so I will guide you through a step by step troubleshootuing procedure to isolate the problem. Since you say theres no spark at the points or plugs, the problem could be in the ignition switch,,,,, or the ballast resistor failed and opened,,,,, , or even the coils primary or secondary failed and opened or is shorting (it MUST have continuity between its lil + and - terminals, does it??, if not its bad),,,,, ,, or the condensor shorted out,,,,, ,,assuming the points are grounded and working okay. The first things suspect are the ballast opened,,, or the points arent closing and opening (and NOT burned up),,,, or the conensor is shorted out,,,,, or finally the coil indeed went bad as you asked.
TRY TO HOT WIRE THE COIL Run a hot jumper wire direct to the coils high (not to distributor) side input terminal and see if the coil fires then????? If so, the ballast may be open or the ign switch is bad, see below. Remove the cap and remove the condensors lead to points, if she fires then, the condensor is shorted, see below.
(I)
*******PRELIMINARY THINGS TO LOOK AT************* Remove the cap and make sure the points are gapped proper,,,,, ,, opening and closing as distributor turns,,,,, ,,NOT burned or pitted or carboned up bad (if so replace),,,,, ,, no wires shorted or pinched. Remove the condensor lead off the points and see if the points spark as distributor is rotated and plugs fire then. IF SO, the condensor is shorted out and needs replaced.
Remove the coil wire out of the distributor (coil end stays in coil) and have that end within 1/8 inch from tractor metal, turn on and crank over and see if it sparks?? If so but not out the plugs when wire re attached, there is a cap or rotor or plug wires or plug problem.
****NOTE***** If the plugs fire as the engine is cranking BUT NOT when you stop cranking but the ignition switch is still on and the engine is still rotating,,,,,the Ballast is open or the ignition switch is bad having no hot IGN output.
(II)
************ PRELIMINARY INFO ******************
For troubleshooting the primary circuit, the current path from the battery to ground is:
From the batterys ungrounded post,,,,,usually to the starter post,,,,, ,,,to and through the ammeter,,,,, ,to the ignition switches BAT input terminal,,,,, ,,,out the IGN terminal on the switch (hot when ON),,,,, ,,, to and through the Ballast Resistor,,,,, ,,, to and through the coils primary winding (lil + and - terminals),,,,, to and through the points (when closed),,,,, ,to ground. *******************TROUBLESHOOTING***************
1) Turn the ign switch ON and place a test lamp or voltmeter on the coils high (NOT to distributor) terminal. IT MUST TO SHOW VOLTAGE (around 6 to 12, dependign on ballast and coil resistance and if points closed and working) to work. When points are open near 12 and closed near 6.
a) IF NO VOLTAGE ON COILS HIGH SIDE: The ballast may be open,,,,, , or the switch is bad,,,,, ,, or bad wirign from the switch to ballast to coil.
b) Take a HOT jumper wire and wire it to the coils high input (not to distributor) terminal and see if she sparks then????? ? If so, problems the ballast or switch or wirign to coil.
c) YOU MUST have voltage to the coil for the points to spark and the plugs fire. See if theres voltage out the switches IGN terminal, then on the ballast high side, then on ballast output to the coil (same as coil). If voltage is to the ballast but not out of it, its failed open.
2) If theres voltage to the coil, next place the test lamp over on the coils low output (to distributor) post. As the engine cranks over with ign switch on and if ballast and switch and wiring all okay, the lamp should flash on (when points open) and off (points closed) IT MUST DO THAT TO WORK. a) If the lamp there never is ON, the condensor may be shorted,,,,, or a short in the wiring,,,,, ,, or in the distributor,,,,, ,, or points shorted out,,,,, , or they never open,,,,, ,, or the coil has an open primary winding,,,,, ,,or a short in in the distributor, maybe the input lug/post is shorted out.
b) Unhook all leads off the coil and check its primary winding between the lil + and -terminals. It MUST HAVE continuity, maybe between 1 to 2 ohms or so dependign on coil, if its an open circuit, coils bad.
c) If the lamp there never goes OFF, the points are bad or not closing tight or theres an open wire to the points from the coil or the distributor isnt well grounded???? The points must close and ground the coils low side to conduct coil current. With ign on if you ground out the coils low side terminal and the coil fires when you remove that wire, the coil and ballast are good, but the points must not be providign a good ground. That can happen if they are badly burend or carboned or not closing tight (CHECK THAT) or the distributors not grounded.
3) If the switch is good (power to ballast input),,,,, and ballast is good (voltage on in and out sides),,,,, ,, the coil is good (has continuity) the condensor NOT shorted,,,,, ,,,the points open n close and a test lamp on low side of coil flashes on and off,,,,, ,,but STILL NO SPARK OUT COIL WIRE TO 1/8 FROM FRAME,,,,, ,,,,,
The coils high voltage secondary may be the problem.
****************SUMMARY************************
Suspect the points (burned pitted not open and closing),,,,, or open ballast (try to hot wire direct to coil),,,,, ,, or shorted condensor (try with it remoived),,,,, ,,,, or a bad ign switch (no power out IGN terminal),,,,, or a bad coil (primary or high voltage secondary)
Greg, If you like I could e mail you the 2 articles on Ignition Troubleshooting I had published in the Green Magazine if you need more details. Post back or e mail any questions to [email protected].
Gppd Luck n God Bles ya Greg
John T Nordhoff
Dan
01-27-2004 07:00:34
On page 5 there is a discussion on the resister on the 630. I have one on a IH 12 volt conversion, it got bad last year and would just shut downlike you turned if off. It would then sometimes restart. Replaced resister and was all ok. On some tractors, not sure about the 630, there is a fuse on the ignition lead that will shut everything down if it goes.
Dan
01-27-2004 06:46:53
There was some discussion here a week or so ago about the 630 and a resister. Not sure if that is in theline from the ignition switchor in the coil. If in line it will sometimes butn out and cause what you are dealing with.
