Early H governor question
Gary Mac
05-12-2004 20:54:10
I have an early '39 H (on of the first 700 made) that has grease zerks on the governor case. Did the early H's have these or is this a "custom" job?
thanks.
Gary
Clooney
05-13-2004 03:14:21
 Re: Early H governor question in reply to Gary Mac, 05-12-2004 20:54:10
Gary, as far as I know those grease fittings were added. The parts books I have [even the originals] show no grease fittings..
~The earliest "H" S/N I have worked on is in the 1000 range so I can't tell you positively if those grease fittings were added later or not.
~The early �H� had governor bearing oiling problems so later on Deere offered a retro-fit external oil line kit for those �H� governors to supply oil to the L/H governor bearing..
~Those �H� governors oiled ok at rated engine RPM but were lacking at low RPM�s.. Problem is a lot of those H�s were used primarily for cultivating & therefore run at low RPM�s for hours on end, that resulted in failed governor bearings so the farmer or dealer just drilled the cover & added a grease fitting.
[email protected]
