345 - Pully keeps working it's way off shaft.
Corey
05-12-2004 19:22:16
As I had the blades turning, the pully assembly that is under the motor(drives the deck belts) fell off and snapped into two pieces. I suspected the bolt and washer worked their way loose. I put the new one back on (on the locator pin and into the keyway) and added a couple of drops of loc tite to the bolt. I just mowed tonight and the bolt is working its way loose again.
Is there a special way I am supposed to tighten this down?
Did I put the washer in backwards?
