Deere B, The first thing that MUST BE HAPPENING for it to work, is that each 180 of flywheel rotation, its producing a loud distinct SNAP sound versus any faint dull clunk. Thats the mags wind n trip spring assembly working which it must to produce a spark at hand cranking. If shes never snapping, the trip dogs may be stuck or dirty or corroded or the springs broke or other things. You can easily remove the cap to insure the rotor tip is turning when you rotate the flywheel and the points are gapped to 0.015 on high cam and openign and closing and NOT burned or pitted or carboned up or gray oxide coated. If so, replace them and re gap. If its doing that (loud snap each 180 of flywheel rotation), remove both plugs but have their wires attached with their sides against the frame for a ground. Then every other mag snap, the plugs should produce a good visible blue and NOT any faint thin wimpy yellow spark across its gap. If the spark is weak or yellow or faint, you could have bad points (burned or corroded or pitted or gray oxide coated) or a weak mag spring or bad wires or plugs or other things wrong. Post back if so and I will guide you through troubleshooting. If the plugs arent firing but shes snapping, remove the cap and again, check the poins for opening to 0.015 on high cam and NOT burned or pitted or gray oxide coated. ALSO if it has a kill switch stud out its side, it cant be frame grounded, nor can the stud be grounded due to bad insulation where it passes through the case, nor can any wire from its inside to the points be grounded, cuz that kills the spark. If shes snapping but the plugs are not firing,,,,, , and the kill switch stud or any of its wires are NOT grounded,,,,, ,,, and the points are workign and not bad,,,,, ,,,, try new wires (use wire core NOT carbon suppressor types) and new plugs and swap to see if either side ever fires????? ? NOTE !!!!! !!!!! Make sure the caps big inner long spring makes contact with the rotor arm tip and its lil spring makes contact with the coils side output button/terminal. If both arent correct, she may be okay but she cant fire via the plug towers. Finally to test for no fire and eliminate any cap or rotor or plugs or plug wire problems,,,,, , remove the cap and attach a wire or paper clip to the mags metal side frame with the other end to within 1/8 inch away from the mags coil side output button/terminal. Then each time you rotate the flywheel and the mag snaps, a good visible blue spark should jump that 1/8 inch gap. If it does there but neither plug fires when the cap is replaced and plugs are wired up, you have a cap or rotor or plug or plug wire problem. Thers plenty more that can be said and how to time etc etc etc and more troubleshooting tips, but for now you just asked how to check without removign the mag, so this ought to get you a start at least. Shes gotta snap and both plugs gotta fire every other mag snap, and if not, the first thing to suspect is the plugs then the points then the cap and its spring contactors then I will post more if you need it. Let me know n post back or e mail any questions and your findings. Good Luck n God Bless John T
