Gaskets needed??
Jason Z in MO
05-12-2004 15:08:14
I am working on an early styled B which is gettng a complete tear down. I'm wondering how much time and money I need to spend finding or making gaskets. I know most are still available from John Deere.
Is it recommended to install new gaskets for all fittings or are the "form-a-gasket" products what everyone is using these days? I know there are critical gaskets required for proper shimming: head, block to main case, governor to main case, etc.
But what about the rest?
havvey
05-13-2004 03:04:08
 Re: Gaskets needed?? in reply to Jason Z in MO, 05-12-2004 15:08:14
this is a common set most dearlers or tractor supply places can get them < $100 has most of what you need to do the engine.
PeteNY
05-12-2004 15:15:17
Jason, I have learned the hard way that since I don't like to do things over, I always replace gaskets with new when available, and make 'em if not, then use the form a gaskets stuf on either side(I like the aircraft stuff; black, comes in a bottle with a brush best), gaskets are relatively cheap. pete
