Adding rear hydraulic outlets to a JD 750 Utility
BigMac
05-12-2004 12:31:49
I want to add a set or rear hydraulic outlets to the rear of my 1984 JD 750 Compact Utility Tractor to control implement lift cylinders. I have a loader on it and a port under the seat to hook up my rear mounted backhoe. The backhoe setup gives me a pressure and return line so it should be easy to tie in a rear outlet setup.
I have been unable to figure out what to use for setting this up. I need control levers and a set of breakaway outlets.
Can anyone suggest a setup or parts source to use for this ?
I appreciate anything you folks have to offer.
Thanks.
BigMac
clarence
03-19-2005 15:07:29
 Re: Adding rear hydraulic outlets to a JD 750 Util in reply to BigMac, 05-12-2004 12:31:49
use a selecter valve under your duel control on your selector valve
Mike M
05-12-2004 19:41:43
I would guess that the backhoe uses a power beyond valve this would need to be verified. Just hook up a valve of the same type as the backhoe and put some quick couplers on the ports that go to the cylinders.
leon
05-12-2004 18:26:37
Have you checked at your local Deere dealer for a kit? Perhaps there is one to do just what you want.
