Engine Help !!!
Thomas
05-12-2004 10:36:42
Here is the problem . I just rebuilt the motor on a 36 B and it starts hard ,runs rough ,no power, and when i pull off the LH plug wire it makes not difference .When I pull off the RT plug wire it dies. The Mag timming "Fairbanks Morse RV2B" is right on the timming mark ,nice blue spark,carb was completly redone by "Roberts Carbs.",new rings ,valves ,valves guides, valve seats , valve springs.I check the tappet gap ,OK .Now where do you go from here ? Any help Please.
Thomas
05-12-2004 17:09:49
 Re: Engine Help !!! in reply to Thomas, 05-12-2004 10:36:42
Well ,I found the problem .It was the mag. The timing is not right using a FM RV2B.I put on a wixco x and it runs great. Now I have to figure out how to set up the Fairbank Morse mag. THANKS TO ALL!!!!!
Mike M
05-12-2004 19:48:37
 Re: Re: Engine Help !!! in reply to Thomas, 05-12-2004 17:09:49
That may be one of those mags. that has a gear reduction inside so it only fires on the compression stroke unlike the X mag that fires both compression and exhaust. If it is one of these the wires go in a different order as the rotor turns backwards from the X mag.Also the inside rotor gears may not be in correct mesh.
Jim
05-12-2004 16:02:25
Thomas. Just another note cuz I made this mistake once. The plug wires must be the old style wire core, not the newfangled automobile style plug wires.
Bob-Wyo
05-12-2004 13:15:41
Thomas if changing spark plug does not do it, is there comp on that cyl when you turn it over? if not then it's time for a air test to that cyl suspect a slightly open valve. Reason is it sounds like my friends D that he tore down 2 times and found nothing. I did the air test and #1 exhaust valve was the problem, we tore it down and I found that machine shop had left valve guide a hair to high and the shoulder on the valve was hitting preventing it to totaly close. The quick air test (if you have no compression) will prove this out.
Just another thought,
Hope it's just the plug or plug wire for you.
Bob
DON
05-12-2004 12:32:46
WITH THE ENGINE RUNNING SPRAY UNDER AND AROUND THE MANIFOLD WITH CARB CLEANER , PENETRATING OIL WHAT EVER YOU HAVE TO SEE IF THE ENGINE SMOTHES UP. A BAD GASKET AREA COULD CAUSE A VACUME LEAK.THOSE OLD MANIFOLDS WOULD BURN OUT INSIDE AS WELL.
Jason Z in MO
05-12-2004 10:45:49
I had the same problem with a 520. First thing I would do it check your plugs. I assume they are new as well but this is worth the couple minutes. Swap the plugs from side to side. The 520 would NOT fire in #1 cylinder. I pulled the plug and had good spark at normal atmospheric pressure but under compression it could not fire.
Next I would insure you have good compression and you have adjusted the valves correctly.
Beyond that, it's time for Clooney and the rest of the pros!
Mike in Louisiana
05-12-2004 14:42:15
 Re: Re: Engine Help !!! in reply to Jason Z in MO, 05-12-2004 10:45:49
don't forget to check plug wires.
Mike
Mike in Louisiana
05-12-2004 14:07:57
Mike
