3010 does not move
David M.
05-11-2004 20:16:03
I have a 3010 diesel that does not move, the ring and pinion turn in rear end but nothing turns on the rear axles. Any ideas what could be the problem, also just went through the clutch and its in good shape.
DON
05-12-2004 06:12:34
 Re: 3010 does not move in reply to David M., 05-11-2004 20:16:03
IF THE REAR WHEEL AXEL HALVES ARE LOOSE THEY WILL SHEAR OFF THE AXEL KEY. STEP ON THE BRAKES ONE AT A TIME WHILE IN GEAR AND THE CLUTCH OUT.
ET
05-12-2004 05:39:37
If you think the trouble is in a final drive try holding the brakes on one at a time when you lock up the broke side the othere wheel should drive. The dowel pins that hold the ring gear were a problem in the 10 sieres. I have also seen a 4010 that sheared the bolts off that held the ring gear to the differential. You can look in the plug hole where you ajust load control on the back and see whats going on.
steve
05-11-2004 20:26:33
sun pinion is snaped off in one axel 50-50 chance on guessing the correct side to start with
david m.
05-11-2004 20:32:14
 Re: Re: 3010 does not move in reply to steve, 05-11-2004 20:26:33
I think that is the problem and I leaning towards the left side.
Russ
05-13-2004 18:56:55
 Re: Re: Re: 3010 does not move in reply to david m., 05-11-2004 20:32:14
Yep! Me too. If I remember correctly, the way I checked my 3010 was to lift both rear wheels off the ground and spin them by hand. the good one will have resistance and you will hear the planetaries growl. The bad one will spin freely.
It's fairly easy, just a bit awkward to handle the axle and tire as an assemble if you want to save a little time. Pull the axle from the transmission and you'll see one half of the sun gear in the planetaries, and the other half in the differential. I think I paid $150 for a used one(half of new).
P.S. I'm willing to bet that you weren't even under a heavy load when it happened either. Just let the clutch out and NUTHIN'!! No noise, no bang, just the sound of the voices inside your head saying NOW WHAT ??!!!! BEEN THERE.
