45 48 loaders
Tye
01-27-2004 03:59:04
I want to build a loader for my 50. Which would be a better design for that tractor? Having a bent main frame like a 48 loader or a straight main frame like a 45 loader? Also is it a good idea to attach the loader to the rear axles or to the main frame of the tractor, ahead of the flywheel? One more question, the tractor is set up with a regular duty rollomatac front end, is this font heavy enough to take the added pressure of a loader? Thank you for any help. Have a good one. ---Tye, VA
John
01-27-2004 07:03:54
 Re: 45 48 loaders in reply to Tye, 01-27-2004 03:59:04
My 48 loader parts book says the loader frame (for a 50) is attached to the rear axle and tractor side frame. The Boom is "bent" and the same boom is used on all the deeres and IHC tractors. I cant answer your question about the Rolomatic axle. The book does prescribe different lift cylinder diameters to match different tractor hydraulic pressures and pump volumes.
