john deere A
keith
05-11-2004 20:02:16
this is my first john deere. itruns good but the hand cluch was hard to put in and out. after takeing apart i found that it had 2 cluch pads that are shot. why is there 2 cluch pads in there?? all the other A's I seen just had one. is there anyone with some old cluce pads that they would sell me?? thanks
keith
Lee
05-13-2004 00:51:32
 Re: john deere A in reply to keith, 05-11-2004 20:02:16
All the other 'A's that you saw were put together wrong? Clutch brake pad goes on the belt pulley to stop the rotating belt pulley - sometimes a guy just gets lazy and puts the new one on top of the old one which gets you two 'pads'.
Inside the pulley are two clutch disks not called pads at all. They are probably OK unless obviously split. Even if they are burnt looking, smelly, and glazed over, they are probably good to go unless they are split. A lot of elbow grease and a good large file can make them look and work slightly better but it won't be long until they look just the same as they are now so why bother?
One reason hand clutches are hard to engage and disengage is that they are not adjusted properly, which is something you'll have to learn to do right when going back together, new clutch disks or not. Most important in this aspect is to get all three bolts to apply the same amount of 'tug' on the clutch pack at the same time. Once this is done then one can adjust for more or less 'pop in' pressure by turning all three nuts 1/2 turn at a time and clutch adjustment is then done by counting the turns on each nut and keeping them at always the same count. Perhaps all that needed doing in the first place was to back off the three nuts a turn or two each? It's a common mistake for new JD owners to do also, don't feel bad about it all. I've done it myself.
mitch
05-12-2004 20:12:41
go to www.oldjd4u.com, you can get the clip on type for about $8 a piece, just bend the ears back and they are on, not as good as the orginial rivit type, but they've always done a good job for me.
mitch
mike in new mexico
05-12-2004 06:57:20
Keith- There are 2 pads in the cluch-one on each side of the driver. They are not expensive,the last ones I bought from the John Deere dealer was about $ 13 bucks.-mike
mike in new mexico
05-12-2004 06:59:41
 Re: Re: john deere A in reply to mike in new mexico, 05-12-2004 06:57:20
I forgot to say that was $ 13.00 each !-mike
