AO clutch problem
crawlercrow
05-11-2004 14:35:43
Clooney,
I have 2 unstyled Ao's.The 46 clutch snaps-in good but the 49 will not snap-in even though the clutch discs are new.As I push the lever forward there seems to be excess movement(3/8")on the pulley itself before the clutch pressure plate engages .This movement seems to change the adjustment on the tightening bolts.If I tighten the bolts any further the clutch will not stay engaged unless held.When I loosen them the clutch slips.Is there some kind of spacer to hold the pulley tighter to the block or do I have a wear problem?I have taken out crankshaft endplay.The pulley on the 46 moves very slightly in comparison.I have checked for broken bolts etc. and found nothing. Hope I have described the problem adequately.Thanks in advance.
Mark
05-12-2004 09:57:41
 Re: AO clutch problem in reply to crawlercrow, 05-11-2004 14:35:43
no spacer, make sure the inside clutch disk hasn't fallen out of place. Is the drive disk going to far on the splines? May be time for a new undersized driven disk.
Mark
05-11-2004 16:09:04
When you took the endplay out of the crankshaft, Did you hold the clutch pulley in towards the tractor by means of a wooden block or jack? Then move the flywheel in to take up the excessive endplay.
crawlercrow
05-11-2004 17:42:02
 Re: Re: AO clutch problem in reply to Mark, 05-11-2004 16:09:04
Mark, I did take the end play out as you described and the crankshaft does not move when running.I previously had a problem with a loose flywheel but have bought a proper wrench and now have it securely tightened.The movement is completely in the pulley itself.When you engage the lever the clutch snaps just slightly with no effort.Any further tightening of the bolts results in less snap and will not stay engaged without holding the lever.
