730 diesel no power
mark
05-11-2004 10:00:43
just bought tractor not real familiar w/ 2cyl but it was just rebuilt, anyway pulling 8 row corn planter (jd 7000) everybody tells me that should have plenty power,seems to missing or ???
but you cant pull it past second gear 3rd gear a small steady flame comes of exhaust and smokes but i need to pull the corn planter in 3rd to make the planter monitor work right 4 to 5 mph.
is there some thing to look at or try to time or something ????? or is this the best it will do
just trying to plant food plots with it just seems like it should have more power our 720 gas seems to have more power somebody out there knows these tractors better than i do I'm just a hobby farmer for habitat and like these old tractors desperate for some ideas
720Deere
05-13-2004 07:16:54
 Re: 730 diesel no power in reply to mark, 05-11-2004 10:00:43
I checked the Deere website and they recommend a minimum of 105 hp for an 8 row planter. I'd say that in the mid 50's, your 730 is under powered. They show 75 hp min. for a 6 row planter.
It's not the tractor, it's just too much load!
720Deere
05-12-2004 06:25:13
An 8 row planter is too much load for a 730. We used to pull a 6 row 7000 planter with a 4020 and it was a load. I would say that 2nd gear is pretty good for that load.
DON
05-12-2004 06:22:43
DID THEY REBUILD THE PUMPS AND NOZZLES WHEN IT WAS OVERHAULED? THE LOW SYSTEM FUEL PRESSURE COULD BE LOW AS WELL. HOW ABOUT FUEL FILTERS? DOES IT SMOKE A LOT? SOUNDS LIKE YOU NEED TO FIND A MECHANIC FAMILURE WITH THESE TRACTORS TO DIAGNOES THIS. COULD BE TIMMING GEARS ETC. HOPE THIS HELPS DON
