Greg, heres a few thigns that come to mind: 1) If its sat very long, the point surfaces could have developed a gray oxide coating. You might wanna non abrasive clean/polish them and check their gap. Ive had a tractor not run after setting and simply ran a shoop cloth through the points to shine them and they were cured. 2) If the plugs even appear slightly fouled or have a lot of a flat black sooty coating, you may wanna try a fresh set since its spring time and it dont cost much and sure cant hurt. 3) A weak mag (if thats what you have) spring or a sticky trip dog assembly can cause a condition where shes hell to hand start but will run fine once over 250 RPM when the spring n trip are no longer functioning. Remove both plugs and have their wires attached and plug sides grounded n crank her over to insure EACH plug produces a good visible BLUE and NOT a faint thin wimpy Yellow spark. If so post back your ignition system and we will go from there. If you have a mag, does it produce a good loud sharp snap or a faint dull clunk"??" If she dont snap or its weak, that can cause hard to a total failure to hand start. 4) On that hard cranking condition: Have you checked the oil to insure it dont have gas in it????? ? If the carbs needle n seat or float were bad and gas left on, you could have gas in the oil and washing off the cylinder walls n rings. Whats coming out the petcocks, raw gas or gas vapor???? 5) Is the choke working and closing all the way??? Have you checked the air cleaners lower bowl to insure its water free????? Is you gas clean n fresh n water free??? Im sure theres more, but check the oil,,,,, ,,, the gas (clean fresh n water free),,,,, ,,,,the air cleaners bowl,,,,, ,,that the choke is closing,,,,, ,,,the points for gap and no oxidation or burning or carbon or pitting (replace if so),,,,, ,,freash plugs,,,,, for a loud sharp mag snap plus each plug producing a good visible blue spark,,,,, and post back or e mail [email protected] your findings or any questions. You may wanna also check for compression on each cylinder as weak compression can cause hard hand starting. IMPORTANT NOTE remove the plugs n squirt a lil oil in the cylinders and see if she starts better then !!!!! !!!!! !!! The oil can help develop a ring seal caused by worn rings or gas washing off the oil seal. If she hand starts better with an oil squirt in the cylinders, I suspect low compression and worn rings causing a hard to hand stagyt condition but run decent once started. HOWEVER, if they or the valve guides were worn real bad, yu oughta get a lil blue smke out the stack or excess blow by when running. Let me know Good luck n God Bless ya Greg John T
