2755 vs 5520
Mike
05-11-2004 06:50:39
I know that this page is a antique collectors page but I thought that there might be a couple of people with some information that might be able to help me. I have a 87 2755 4wd with cab and loader and am considering trading for a John Deere 5520. My tractor is in great shape with 3200hr. The reason I'm toying with this is that I like the wet clutch and shuttle on the newer tractor and it is alittle smaller and lighter for some on the wet areas I encounter. Is the 5520 a good tractor and am I getting a comparable tractor by getting it. I know there is some thoughts that the --55 series is a actually a better unit than the present ones on the market. Thanks for your help.
leon
05-12-2004 05:03:20
 Re: 2755 vs 5520 in reply to Mike, 05-11-2004 06:50:39
The 5520 is a much different tractor than the 5400. First, the cab on the 5400 is a piece of junk, while the cab on the 5520 is something to be proud of. Then too, the 5400 is a 3-cylinder engine tractor while the 5520 is a 4-cylinder engine tractor. The 5520 has a longer wheelbase and more weight than the 5400. I'm not sure if the synchronized reverser is available on the 5520 configuration you're looking at or not (it's available on the "N" tractors) but if availabble, it's about as good as the power reverser and is less money.
I think you'll find the 5520 a worthy replacement for the 2700, especially if you're looking for something a little smaller and lighter. However, keep in mind, that if you're going to do the same things on the drawbar or with the loader of the 5520 as you do with the 2700, you'll need to weight up the 5520 to about where the 2700 is.
Jerry Millsap
07-02-2005 07:18:20
 Re: Re: 2755 vs 5520 in reply to leon, 05-12-2004 05:03:20
In an unrelated question, from one who has no idea about tractors. What would be the value of a 87 JD 2755? and where can one find a breakdown of the specs for individual tractors. I'm in the process of looking for one to use to mow acreage(brush hog) but cant seem to find the information that would tell me HP, details about the tractor and other usefull info in my search.
Paul (ND)
05-11-2004 18:56:50
Ten years ago I looked at a JD 2750 vs. a JD 5400 both with factory cabs and loaders (they were about the same price). I bought the JD 2750 and
am very happy I did. The cab is much quieter with much less engine noise and vibration.
