Dubuque oil filter assembly
Terry G
01-26-2004 23:03:43
What is the purpose of the "#M1304T" washer? As shown in PC505 catalog. Not the "#M88T" which often sticks to the filter. But the smaller washer. If added or removed, does this washer affect oil pressure? and in what way?
Im guessing that the washer is used just to center the paper filter element. I can find no reference to it in the "OM" or "TM" manuals.
thanks all.
Clooney
01-27-2004 03:11:59
 Re: Dubuque oil filter assembly in reply to Terry G, 01-26-2004 23:03:43
Terry, to know for sure we would have to ask the original part release engineer..
~An educated guess would be to improve filter base sealing to the M-88T washer. That M-88T has a large center hole & sits down a ways on the filter casting.
~One thing to keep in mind is: that oil filter elements have changes & evolved over the years & in a lot of cases now fit multiple models..
~To answer your question...."If added or removed, does this washer affect oil pressure?"....>>>> Answ, maybe... Could you actually see the oil pressure difference on the gage, probably not..
~Most of the new filter elements have a solid bottom & seal pretty good on the bottom anyhow so that washer probably won't make much if any difference.. Even the M-88T doesn't help that much if the filter element has a solid firm base on it..
~I would think the filer element micron size would have the biggest effect with a well used filter being the best for oil pressure..
~Remember that oil filter is a by-pass filter so the less oil that gets around it or through it the more flows through the unfiltered part & that is the oil that lubes the bearings.
~Even if the filter element were completely removed there is still a drain back or flow limitation hole in the filter casting base to limit the amount of oil that can by-pass the main oil system & return to the sump..
[email protected]
tom
01-27-2004 02:18:56
Terry,
I asked a JD parts man this one time and he did not know either...he did give me an original or cross reference number ofr M1304T and it was: 24M7085...i never looked it up but maybe this can help you.
tom
Terry G
01-27-2004 03:10:40
 Re: Re: Dubuque oil filter assembly in reply to tom, 01-27-2004 02:18:56
Thanks Tom, I have the part somewhere. I know they can cross it to a current part, which is just a washer. But more wondering why its suppose to be there than anything.
TG
