Hilltopper, as you have found those diesel noises telegraph all over the engine & transmission so the noise origin is very hard to locate & isolate.. ~With the above in mind it�s very hard to help with engine noise diagnosis over the internet.. It�s hard enough to isolate engine noises when actually working with the tractor.. ~When I first read your question above a couple of things stood out�Quote: �The sound seemed loudest at the first reduction gear� -- & Quote: �With the clutch engaged it is a little quieter than when it is disengaged���.. ~I�m wondering if the crankshaft internal counter weight is coming loose [it�s bolted on].. If the crankshaft was worked on & that weight wasn�t properly tightened it�s a possibility� ~I guess if I were working on that noise in my shop the first thing I would do is use some quick drying paint or epoxy & put a dab on the flywheel end of the crankshaft between the flywheel & crankshaft then let it dry.. That will show if there is ANY flywheel to crankshaft movement. Those flywheels can sometimes make noise & yet seem tight.. ~Next I would remove the big PTO idler gear to see if that is adding to or is the noise producer.. ~Next I would pull the pump cover & crack injector lines with it running to see if one side or the other can effect the noise.. [a malfunctioning injector can really make a noise difference in those 2-cylinder diesels].. If cracking an injector line changes the noise then remove that injector & turn it around then crank the engine & look for a clean spry pattern with a fine even mist [maybe compare it to the other side] CAUTION: don�t stick you hand in the injector stream as it can do serious hand damage. ~It might not hurt to re-check the injector timing.. ~I presume you have listened to the Power-Trol pump area with that stethoscope? ~Another place of concern in those 2-cylinder diesels is the cam drive idler gear(s) .. There is a problem with the idler gear bearing [mostly on the 70D & real early 720D that causes noises & cam timing problems but that isn�t such a pronounced knock as you seem to have.. ~About all that�s left is the center main bearing, or governor, or piston pin wear.. Even a loose piston in the bore can knock like crazy under certain conditions.. ~One last thought�If that noise came on all at once & you added fuel prior to that time suspect a large amount of gasoline in the diesel fuel, that will cause a hammering like the engine is coming apart.. Let us know if you find anything.. You might also try calling Albert at Renaissance Tractor [I don�t have the number handy] he is a wealth of knowledge on those 2-cylinder diesels & can maybe help you pin that noise down.... [email protected]
