4020 ROPS noise
Merlin in Saint
05-10-2004 14:11:52
Hi, Folks! Spent a beautiful afternoon in Southern Illinois on Saturday, running a 4020 diesel powershift with ROPS on a bat-wing mower. Pretty nice old tractor, but the one problem I noticed was an incredible amount of noise transmitted from the transmission to the axle housings and up the ROPS frames, resonating in the side posts and canopy. This noise is only apparent when the PTO is engaged. Are there any good ways to cut-down on this noise, such as rubber iso-mounts? The foam is long missing from the underside of the canopy, and earplugs barely took the edge off of the noise. Any ideas would be appreciated. Thank you!
Merlin
Merlin in Saint Louis
05-11-2004 15:04:24
 Re: 4020 ROPS noise in reply to Merlin in Saint Louis, 05-10-2004 14:11:52
Thanks for the good advice! I was wondering about filling the posts with insulating foam or something. Sounds like a good place to start.
Merlin
Jason Z in MO
05-11-2004 14:12:41
Is this howl normal or is there a problem with the PTO???
I have a 4020 and when pulling a heavy PTO load (hay mower or 15' batwing) I hear a noise in the PTO train... I wouldn't discribe as loud and you do but I don't have the ROPS and canopy to act as a speaker...
JDBert
05-10-2004 14:59:23
Rubber around axe at mounting points and since those should be hollow tubes for the ropes, drill a hole in the top and fill them with silica sand.
Bill
05-11-2004 09:35:08
 Re: Re: 4020 ROPS noise in reply to JDBert, 05-10-2004 14:59:23
It's been a lot of years but I think the ROPS on our 4020 came from the factory filled with sand. Maybe that was the factory fix to the problem on later built ROPS. I sorta think the ROPS on our 3020 was hollow, sometimes you'd get a vibration but nothing continuous. On the 3020 we also had the fenders bolted directly to the ROPS.
