D Cylinder Inserts
Tony
05-10-2004 09:38:52
I have a 48 D that my uncle, or the owner before put in cylinder inserts and had to take them out because they had turned inside and killed #2 for over twenty-five years. My question is, How much more horse or displacement will these inserts help on the D's? Were the inserts common on the D's? Now they are out and pulled a disc on fresh plowed ground up a hill at 3/4 throttle and the tractor did not know any thing was behind it.
Thanks for any inputs
Tony
Clooney
05-10-2004 10:43:04
 Re: D Cylinder Inserts in reply to Tony, 05-10-2004 09:38:52
Tony, you ask...
Quote: "My question is, How much more horse or displacement will these inserts help on the D's"...>>>
_Well they don't add any displacement but do add some compression & therefore a little extra horsepower. Those inserts [compression donuts] were installed so the engine could more efficiently burn gasoline as gasoline had a higher octane rating than kerosene or tractor fuel & could utilize the higher compression.. As for a horsepower gain? I have no idea but it was noticeable when pulling a plow..
Quote: " Were the inserts common on the D's?"...>>>
_That depends on the area.. In some areas of the country there seems to be quite a few floating around & from others there doesn�t seem to be many.. I would think it depended on the use of gasoline as tractor fuel in those areas & if those donuts were readily available..
~You say that one had spun in the cylinder? The spark plugs are supposed to hold those inserts in place & keep them from turning.. Did your tractor have a short spark plug in it on that side?
[email protected]
Tony
05-11-2004 05:19:11
 Re: Re: D Cylinder Inserts in reply to Clooney, 05-10-2004 10:43:04
The plugs were long enough that at times when you put them in the ground would bend over and touch the post. I would have to say they were short ones. But it starts on the second turn of the flywheel. My uncle switched it to hand crank when the starter went out. (don't sound cost effective), but it works.
Thanks Clooney
