Your high pressure line from the front pump comes back over the engine and goes to the steering priority valve at the RH upper side of the dash console. From there, a steel line goes to the original hydraulic valve(s) (SCV(s)). This is the area you need to source the high pressure oil from. There is a six-cornered (hex) plug in the bottom of the steering priority valve that can be removed, and the proper fitting installed to provide oil flow to your exteral loader valve. Note: 1.) If I recall correctely, there were some variations in the steering priority valves on EARLY 4010's. I'm not sure if this would be an issue here. 2.) If you have a 3-point hitch, the line that feeds oil back to the hitch control is already connected to the port mentioned above. You'd have to figure out a way to tee into the line for the 3-point. For proper operation, the return oil from the loader is returned to a special transmission oil filter cover (available as an accessory from Deere), where it is filtered and returned to the front pump. Hooking up the external valve without returning the oil to the filter cover will starve the front pump for oil when the loader is being used. As far as the loader valve is concerned, assuming all levers are in neutral (centered position), identify the "P" (pressure) or "T" (tank) ports on the valve. Blow air into the "Pressure" port. ...closed center valve... NO flow out "return" ...open center valve... air flows right through the valve, and out the "tank" port. Some valves are convertable from open to closed center by the addition of a special plug. You would need to identify the valve you have, and get the manufacturer's data sheet for it to see if this applies to the valve you have.
