4010 Steering motor
Kevin
05-10-2004 06:21:27
I have a oil leak on a Seal(s) on the steering motor of a JD 4010 row crop wide front end. Obviously the motor has to come out to replace the seals. Do I have to remove the entire front end to drop the motor out or will it drop down the slide out to one side or the other between the bottom of the tractor and the pivot frame? Also is it better to reseal/rebuild the motor or purchase a rebuilt unit? Thanks!
Russ
05-11-2004 19:18:33
 Re: 4010 Steering motor in reply to Kevin, 05-10-2004 06:21:27
I just did one on a 3010(same baby). You have to drop the wide front out because you need the room, and that sucker's HEAVY!(I used 2 pieces of angle iron bolted to the spindle with the help of a bottle jack and another person to get it in and out) Also, you'll need to drop the left frame rail out so you can angle it for removal.
Re-building it is simple. You just need to be cautious when re-installing the rams so you don't cut the new seals(there's a chamfer on one side for this at the spindle area/ you'll see what I mean). The spindle needs to be "timed" also. There's an arrow on the spindle, and two hash marks on the housing for indicating full left and right limits. You simply put two of the end plugs in diagonally from each other and install the rams until they contact the plugs. Then you install the spindle and time it to the appropriate hash mark. An "IT Manual" is cheap enough and has it step by step. Easy Stuff.
Kevin
05-12-2004 17:31:54
 Re: Re: 4010 Steering motor in reply to Russ, 05-11-2004 19:18:33
Russ,
Thank you for the info!! I have a Deere Service Manual for the tractor and it gives step by step but not alot of illustration. Do you know if the IT manual does a better job of describing the repair? If so maybe I'll spring for the IT book. Thanks again.
Kevin
