Air in JD 620 hydraulic system
Dean Van Peurse
05-09-2004 23:55:07
I blew a hydraulic hose on my JD 620 today and had to take both pipes and hoses off to repair it. Lost 6 quarts of oil. Repaired it but now I have a hydraulic system full of air.
I had the two bottom JD 820A roll over plow on when it blew, so I probably have air in the dual plow cylinders too. The tractor hose blew when I was rolling the plow over. Thank goodness I had a back up set of used hoses and pipes. I don't think those hoses are available from Deere any more. The Power-Trol is making a nice squeal sound now! A free but unwanted added bonus! :-)
What is the best way to bleed the system? Or is something else wrong?
Clooney
05-10-2004 11:22:55
 Re: Air in JD 620 hydraulic system in reply to Dean Van Peursem, 05-09-2004 23:55:07
Dean, you say..
Quote: "The Power-Trol is making a nice squeal sound now"...>>>
_Do the hydraulics operate or is the system non functional? If the system is non functional then you either have something blocked off or connected wrong.. If the system is operational but just air bound then it will probably eventually bleed itself with use...
[email protected]
Dean A Van Peursem
05-11-2004 21:15:28
 Re: Re: Air in JD 620 hydraulic system in reply to Clooney, 05-10-2004 11:22:55
Clooney:
Yep, it is working but with considerable groaning, moaning and squeeling. Will keep exercising it and see if it clears up. Thanks
