MDM, Im not much of a D man, but can offer a few things until some D owners can add other tips n opinions. The petcocks are on the back side of the piston when shes initially drawign in air and then when shes compressing past them, so I dont see them as your immediate problem. 1) I guess you have tried different choking procedures?? I usually have the throttle set to a bit above idle and then I have good luck using full choke not much more than 2 or 3 piston compression turn overs, then 1/2 to 3/4 choke. On others, I use choke until I start to get vapor out the petcocks, then open the choke some and she starts. Are you choking and are you ever gettign gas vapor or gas out the petcocks??? Excess raw gas will wet foul the plugs, once I get vapor out I open the choke some. 2) Does it have the primers as mentioned below and have you tried that??? 3) What do the plugs look like??? Once they get too much wet gas fouling I dont have good luck with them afterwards and suggest you try a fresh set if they have been gas wet too an excess or appear fouled or excess black sooted. 4) In many cases, a weak or inoperative mag spring and trip assembly allows for easy pull but never hand starting!!! Does she snap loud sharp and distinct or is it more like a faint dull clunk??? If so, you may have a weak or bad spring wind n trip assembly. Once over 250 RPM or so, the wind n trip n spring are out of operation which is why it will pull start but not hand start. Remove the plugs and observe if BOTH produce a good visible blue and NOT a faint thin wimpy yellow spark when the mag snaps. If so, that could be the problem so post back what mag you have and we will proceed from there. 5) If the mag snaps loud n sharp and both plugs produce a good visible blue spark, I would install fresh plugs just to be safe,,,,, ,, Set throttle above idle,,,,, ,,,Try the primer cups with gas if it has them,,,,, ,, Choke it full 2 or 3 turns or until you get some gas vapor out the petcocks,,,,, ,open the choke to the 1/2 to 3/4 or so,,,,, , and see what happens. Hopefully that may get you by until some D owners can add more tips and opinions, but I would definitely check the plugs and hand crank spark quality and install fresh plugs and try the choking procedure above in the meantime. Plugs (wet fouled, try fresh set) and/or a weak mag spring sure comes to mind from what you say. Good Luck n God Bless ya MDM John T
