Larry
05-11-2004 03:06:38
Re: 410 john deere backhoe in reply to Tim, 05-09-2004 19:07:08
Hi Tim, can't really help you with the question, but if you'll post it on the crawler section of this site, there is a a guy that I'll bet can give you some good advice--jdemaris... I've got a JD400, which I'm guessing is the model prior to yours. What its worth, I can't really say, when I bought mine the guy who owned it told me the hydralic pump was bad and the front end was loose where it mounted on the engine. I've got the front end fixed and a new drive for the hydraulic pump, and everything works, although it isn't working exactly right...as soon as I get done planting and my alfafla put up I'm going to get to work on it again, I think it may need a new pump in the transmission and a new ring on the flywheel. Hard to say was kind of value to put on it...right off the top of my head, I'd say offer him 1500 dollars and see if he'd take it, my guess is you'd have a couple of thousand dollars having it fixed in a shop...maybe more, who knows, but it you can do it yourself, you might just get lucky and not have a whole bunch of damage when you get into it. One the other hand, I'd guess there are several thousand dollars worth of parts on it, if you were to part it out a piece at a time. Post this again on the crawler section, you'll get some better advice there. It will be interesting hearing what you find out, since I'm going to be getting into mine in pretty much the same way.
