1984 JD Needs New Dual Clutch
Steve Elfreich
05-09-2004 18:06:52
I have a '84 JD 950 and the dual clutch is out so I can't ingage my PTO. I was wondering if anyone knows were I can by a remanufactured clutch for this tractor. JD wants $1200 there has to be a cheeper way. Also is there a chance that a guy could just replace the friction disks instead of the entire clutch? or does everthing have to go at once.
Thanks Steve Elfreich.
Mike M
05-09-2004 18:50:14
 Re: 1984 JD Needs New Dual Clutch in reply to Steve Elfreich, 05-09-2004 18:06:52
Are you sure it's out or is it stuck ?
Steve Elfreich
05-09-2004 18:54:10
 Re: Re: 1984 JD Needs New Dual Clutch in reply to Mike M, 05-09-2004 18:50:14
Well How would I know weather it was stuck or wore out? How can it be unstuck? is it possible to tell this for fix this with out spliting the case open?
Mike M
05-10-2004 05:22:25
 Re: Re: Re: 1984 JD Needs New Dual Clutch in reply to Steve Elfreich, 05-09-2004 18:54:10
It almost sounded like you had it split allready.
Do you have any history with this tractor ? Can you explain your problem in more detail.
steve elfreich
05-10-2004 13:51:18
 Re: Re: Re: Re: 1984 JD Needs New Dual Clutch in reply to Mike M, 05-10-2004 05:22:25
All I know is that when I push in on the clutch all the way It is supost to stop the gears from turning so I can ingage my PTO it will not do that. All It will do is grind and grind and grind. the clutch works great for changing gears and starting and stoping. it is the dual part that seems to not be working. I have the clutch ajusted perfectly it only has about 1/2 of free travel and I even ajusted that out and used all the peddel movement to engage the clutch and it still did not engage the dual part of the clutch. NO i don't have any tractor history I just bought it and found out it did not work. all the rest of the tractor is great.
Mike M
05-10-2004 19:00:00
 Re: Re: Re: Re: Re: 1984 JD Needs New Dual Clutch in reply to steve elfreich, 05-10-2004 13:51:18
My first guess would be a stuck clutch but with out any prior knowledge of it working or not who knows. I would test the pto gears by putting pto in gear then starting the tractor by holding in on the safty switch if it has a push button type or you may have to temporarily bypass it and see if shaft is capible of turning.If it turns with no grinding hook up a brush hog and go mow holding the clutch pedal down as much as you can mainly when you hit a big clump and set the mower down on it trying to shock it loose.If by some chance you know someone with a dyno hook it up to it and load it down with the pedal pushed down. If all else fails you can split the tractor and free it up and clean it.
