JD 317 and 31 rototiller
Jay
05-09-2004 10:39:03
I have a JD 317 and am looking for a rototiller i have a model 31 #116504 in good shape can i somehow use it. the 31 appears to be for a 110 or 112 but attaches to the rear of tractor. I need the upper lift and pivot links. as well as making the pulley work. need ideas
Bob
05-10-2004 08:49:34
 Re: JD 317 and 31 rototiller in reply to Jay, 05-09-2004 10:39:03
The 31 tiller lacks a 90 degree gearbox to match it up with the rear PTO accessory shaft that comes straight out the back of the hydro.
The lift link should be doable. It connects to the rockshaft under the tractor and passes though the slot to the RH of center in the rear frame of the tractor, and connects to the tiller.
Perhaps you could mount a separate engine on the tiller and drive it that way, as Cub Cadet did.
Also, Deere made a hydraulic tiller drive for some of the newer units that hung under the front of the tractor, and was driven off of the electric clutch. Oil lines ran back to the tiller and powered a hydraulic motor. This would be possible, also, but costly, unless you had access to used parts!
Perhaps the best plan would be to swap the tiller for a #33 that will fit the 317, but, of course, you'd still need the rear PTO kit, unless your tractor already has oe.
