How to remove upper air filter element on 420?????
denjoe
05-09-2004 09:38:02
Considering myself a fairly good mechanic this has me stumped. So...since I don't have an operator's manual, how do you get the ding dang upper element off/down/out?? The oil bath pan is pretty obvious but I can't figer' this one. Help!
Ray
05-09-2004 17:41:51
 Re: How to remove upper air filter element on 420? in reply to denjoe, 05-09-2004 09:38:02
The upper element doesn't come out it's welded
to the canister,it's just wire,nothing to clean.
Wayne in Tn.
05-09-2004 14:08:36
Denjoe, first you will have to have the hood off. Then there is a bolt running horizonal behind the cannister, this takes a 9/16 socket and open end wrench, just loosen it up good, then there will be a clamp around the pipe with a bolt to the radiator-light bracket support.
air cleaner picture
05-09-2004 16:46:49
 Re: Re: How to remove upper air filter element on in reply to Wayne in Tn., 05-09-2004 14:08:36
third party image
Just a picture to help see what's required..
Clooney
