Front Wheels?
Tugboat
05-09-2004 09:32:35
My 1951 JD AO has two front wheels (with rubber tires) that are slightly different from each other. Is there a number stamped on JD front wheels that can help me to see if one (or neither) is correct?
Thanks in advance!
Ralph
05-09-2004 18:09:01
 Re: Front Wheels? in reply to Tugboat, 05-09-2004 09:32:35
I could check my 50 AR if you want.
Duane Larson
05-09-2004 14:50:04
Tugboat,
I think your AO came with JD1275 non-reversible front wheels. Best as I can tell, they are not stamped. Why not, I don't know, as all other wheels from about that time were. It replaced the non-reversible JD1261, which was not stamped either (as I recall - my wheel books are packed for the Portland swap meet). JD1275 is a wheel I am looking for more info on, as I think it is 4 1/4" wide and not 4" as most 16" wheels.
F-I-T
05-09-2004 13:18:51
Tugboat:
If it's like the JD 1274 and JD 1290 wheels used on models like my 70D, there should be a part number embossed (stamped) near the valve stem hole. It might take some scraping to find it!
Frank
