JD 5020 oil pressure
stan
05-08-2004 22:50:11
During the operation of my 5020 the oil pressire is at 20 psi with eng at operating temp. At idle it is almost not showing pressure. The repair manual says to incerase pressure by turning in a screw by the tac. drive. Is this something I should mess with? I would like to see a little more pessure at idle.
John Jenkins
05-10-2004 06:54:30
 Re: JD 5020 oil pressure in reply to stan, 05-08-2004 22:50:11
If the gauge is not new, the first thing I�d do is check the pressure with a new gauge just to make sure you are getting a correct reading.
Brokenwrench
05-09-2004 05:07:21
Get the oil pressure up within specs.if the adjustment will bring it up. I would also be a good idea to drop the pan and check the bearings, the oil pump and drive gears to find the cause of the low oil pressure.The oil pumps tend to wear at the top of the housing due to the side load from the gears.That is an expensive engine to have to rebuild,or replace if it spins a bearing or tosses a rod out the side.
