730 diesel using to much fuel
mark swenson
05-08-2004 21:55:28
we bought 730 diesel( been rebuilt what was all done ???? great looking tractor) starts, runs,fine but start working it and it just eats fuel, none in the crankcase that we noticed 730 gas has more power than the fuel one cant find anybody in my area familiar with 2 cyl. how much fuel do they burn typically.Chiseled 15 acres of trees 1/2 tank of fuel maybe thats normal,seems to be lacking power also
Randy V
05-11-2004 03:59:13
 Re: 730 diesel using to much fuel in reply to mark swenson, 05-08-2004 21:55:28
Mark, I had a 730 diesel that always seemed short on power. was all it could do to pull my 14 ft bw jd disk in 3rd and it used way more fuel than i thought it should. the problem ended up being fuel pressure. there is a fuel transfer pump located right in front of the pony motor that pumps fuel through the filters to the injector pumps. this pump should be putting out between 18 and 26 psi. if it is 18 psi or less it will run good but won't pull. It is best to have as close to 26 psi as possible. the better the pressure, the better the power. for a possible quick fix, there is a check valve in the return line coming our of the top of the block cover. you can check it for pressure and if it is low put a couple of washers under the spring and see if this helps. PS. my dad's 730 diesel would pull 4-14" plow in alfalfa 8"deep for 10 hrs on a tank of fuel. he would pull it so hard that he would offen kill it.
buickanddeere
05-09-2004 17:32:07
Does it smoke? What HP does it make on a dyno? Is the aircleaner oil pot and the mesh clean? Is the aircleanerinlet pipe clean the entire length?
Hilltopper
05-09-2004 16:59:26
A 730d running at full load should burn about 3 gal. per hour. Half a tank would last about 3 hours. Chiseling is hard work if the chisel is run deep. Hope this helps.
