jdemaris
05-09-2004 18:47:23
Re: 4430 slow hydraulics in reply to Ryan in Illiinois, 05-08-2004 21:17:27
You didn't mention if the pump is making any noises, if the other hydraulics are working well, and if you're having any starting/cranking problems when the engine is hot. Turning up your pump is not going to trash it, but it's not going to increase the flow/output either - just the stand-by pressure. There are MANY things that can cause your problem, so you need to be deductive. The pump must be fed oil to work. It does not need to be fed pressure oil, but it must have a flow of oil available. You could unhook the feed line to it, and flow check it by letting it run into a 5 gallon pail with the engine idling for a few seconds (a gallon in 10 seconds would be 6 g.p.m.). If the pump is getting ample oil, then you need to ascertain if it's loosing high-pressure oil somewhere before it gets to the rockshaft. If the tractor starts well, steers well, and the hydraulics aren't getting overly hot, then that is probably not the problem. Keep in mind that the main hydraulic pump can get slowly worn just like an engine can - and get slower and slower over time. The pump has eight pistons that ride in bores, eight inlet valves, eight discharge valves, a stroke-control valve, and a few other essential parts - all of which can get worn over time. If a pump gets excessively worn and the piston bores are scored, there IS no repairing or rebuilding it since the bores are not replaceable. Often though, something a simple as the stroke-control valve gets worn out, and replacing it is all that's needed.
