'47 B oil
harley1983
05-08-2004 19:34:36
I have a styled 1947 B john Deere and have a question. Is the oil filler cap on the right side just above and slightly behind center of the belt pulley, and is there an oil indicater plug somewhere to tell how full the crankcase is, and how much should it hold. Thanks in advance, Harley1983
Ravgardner
05-09-2004 04:18:48
 Re: '47 B oil in reply to harley1983, 05-08-2004 19:34:36
You've spotted the oil filler for sure. Looks like an end cap for a water pipe. The oil check is below the belt pully. Use a wrench to loose the nut/needle valve and turn it out. If oil does not come out it is to low. I don't have the specs on the quantity of oil, but my 44 B takes 7.5 quarts. Yours will be close to that
harley1983
05-09-2004 07:21:24
 Re: Re: '47 B oil in reply to Ravgardner, 05-09-2004 04:18:48
Thanks a bunch. I was pretty sure that was the cap, because of the positioning, but I didn't want to fill the hydraulic tank with motor oil. Appreciate the help, Harley
