Clooney or John T - D questions
JC
05-08-2004 18:37:57
Just started up the "D" I'm restoring and I have a few problems;
1. Water is seeping out of the threads past the nut on one of the head studs. We cleaned the threads with tap and die so that they would torque accurately. Can I remove one head nut to apply sealer to the threads or do I have to remove the rad, and tappet case, and loosen all of the nuts evenly?
2. The crankcase breather looks like it has a horse-hair element which is discintegrating. Can the horse-hair element material be replaced with a modern element of some kind? 3. The oil bath air cleaner element has been soaked for ~2 months in diesel fuel and then it was steam cleaned. Particles and dust keep coming out of it when I blast it with air [175 psi}. Is there a good way to clean it thoroughly, or modify it to take a modern dry element air cleaner?
Thanks,
JC
Clooney
05-09-2004 06:34:32
 Re: Clooney or John T - D questions in reply to JC, 05-08-2004 18:37:57
JC, you ask...
1. "Water is seeping out of the threads past the nut on one of the head studs. We cleaned the threads with tap and die so that they would torque accurately. Can I remove one head nut to apply sealer to the threads or do I have to remove the rad, and tappet case, and loosen all of the nuts evenly?"...>>>
_You should be able to just remove one nut & seal the threads on that one.. If you are using those newer copper washers try to find some original lead washers or just use regular hardened steel washers with Loc-Tite PST sealer on each side [I hate those copper washers].. When done, re-torque all the nuts you can get to..
2. The crankcase breather looks like it has a horse-hair element which is disintegrating. Can the horse-hair element material be replaced with a modern element of some kind?...>>>
_I have used that plastic mesh that my wife uses for dish scrubbing [can't tell you the brand ]..
3. "The oil bath air cleaner element has been soaked for ~2 months in diesel fuel and then it was steam cleaned. Particles and dust keep coming out of it when I blast it with air [175 psi}. Is there a good way to clean it thoroughly, or modify it to take a modern dry element air cleaner?"...>>>
_You will either need to drill it apart & remove the inner element to completely clean it, or have it boiled out in a hot tank... It's next to impossible to get those clean inside while the element is still inside that can..
[email protected]
