Dribblin' 6 volt Battery
F-I-T
05-08-2004 18:13:03
Well, the old six volter that I had in my VAC Case gave up the ghost today, so I bit the bullet and ordered an Optima 850/6 Redtop. it was the only 6 volt maintenance free battery I could find, but it sounds like it will provide lots of cranking power.
They do have a plastic fake case if you want to disguise the installation, but that was an additional $65, so I passed on that. It might be cool in a show tractor.
I'll let you all know how it works out.
Frnak
Clooney
05-09-2004 06:17:01
 Re: Dribblin' 6 volt Battery in reply to F-I-T, 05-08-2004 18:13:03
Frank, if your old battery is a plastic case battery just cut the bottom out of it, then remove the internals, then clean it out good & wire that gel cell to the old posts & make your own fake battery.. I haven't ever tried it but it sounds good on paper anyhow..
[email protected]
F-I-T
05-09-2004 07:44:58
 Re: Re: Dribblin' 6 volt Battery in reply to Clooney , 05-09-2004 06:17:01
Clooney:
I might just try that. I'm curious to try one of these Optima batteries. I used to use gel cells in the old days of model airplanes. They were convenient in that they would never drip or slop electrolyte.
Frank
Clooney
05-09-2004 09:31:22
 Re: Re: Re: Dribblin' 6 volt Battery in reply to F-I-T, 05-09-2004 07:44:58
Frank, if you get something that looks & works good post some pictures..
Clooney
hERBn
05-08-2004 18:53:43
Thanks for the info. Frank. Hope the 6 volt works well for you. Guess I will pass on the fake case for now if they cost that much. Haven't had a chance to check local prices.
