8640 cylinder head
Walt
05-08-2004 16:29:30
I bit the bullet and pulled the head off, I see some splatter markes between a couple of cylinders could be the source of my problem Pressure in the radiator? I also noted that the block was lacking metal between the sleeves it almost looks like it might have broke out when the liners where change by the previous owner, Is this common?
Bob
05-08-2004 23:14:52
 Re: 8640 cylinder head in reply to Walt, 05-08-2004 16:29:30
The cracked out metal between the sleeves is typical. Deere has all kinds of go/no go specs for what will pass for re-use. You need a Deere manual and some advice from someone familiar with these engines, after they have a visual on it. Remember, the sleeve seals to the head, not the surrounding metal, so sleeve "standout" is critical. Also, suspect sleeve pitting in the "O" ring area at the bottom, and pinholes in the liners from cavitation.
Walt
05-09-2004 10:39:49
 Re: Re: 8640 cylinder head in reply to Bob, 05-08-2004 23:14:52
The liners don't apear to have any pitting but there is a sign of pitting on a couple firing rings on the head side. I'll take the head in and maybe it can be shaved to get rid of the pitting. The pitting on the head looks like it is due to coolant leaking into this area and vapourizing during compression.
